68 TI Amp Bolt Configuration Question - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    My guess is that the bolts going through the TI amp did not have flat washers between the bolt and the amp. Does that appear to be correct?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 68 TI Amp Bolt Configuration Question
    That is correct no flat washer. The bolts had no treaded upper shank and the nut had a attached star lock washer. Most common bolt markings are TR but have seen RBW and Rockford and both silver and black finish. Paul 18046
    • Jack C.
      • 1090
      Thanks Paul.
      Jack Corso
