Hello Guys,
I have had my half-shafts rebuilt on my 1980 C3 and am in the process of installing.
I have the type of u-joint that uses a strap and bolt with 5/16th head. I am confused about the torque specs. My shop manual says 15ft/lbs for the inner u-joint (differential) and 75ft/lbs for the spindle. Is this correct? Why the big difference?
When trying to torque the spindle bolts with the 5/16th head, I stripped 2 due to the position. There seems to be no good way to get to the bolts.
Any suggestions? And should I use locktite on these?
Thanks, David
Thanks, David
