Air Temp and performance ? - NCRS Discussion Boards
  • Jack P.
    • March 19, 2009
    • 1135
    My son and I where out in my 66 L79 , air temp 24*, top down, and the following discussion came up about performance and air temp.
    Son said he has a 420hp plus WRX STI mod. Subaru rice burner.
    "cool temp allows cars to have better performance and gas mileage."
    My question? All conditions being the same : humidity, clear day ,etc. race car, drag car issues not apply (tire friction etc)
    Which day would my 66 get best performance and gas mileage ?
    (car timing mapped for 2500 - 3500 rpms 50 *) without any adjustments for each day
    30*
    60*
    90*
    Which day and why?
    Jack
    Re: Air Temp and performance ?
    Jack -
    Rule of thumb is a 1% power increase for each 10*F reduction in intake charge temperature.
    • Clark K.
      • January 12, 2009
      • 536
      I have been told my performance dynomometer technicians that there is an air temperature correction factor used when you dyno your engine. The cooler the ambient (existing) air temperature, the more power.
      I believe that is because the air is denser at colder temperatures, more oxygen molecules per given volume of air. -Clark
      • Michael W.
        • April 1, 1997
        • 4290
        Jack -
        Key words are 'intake charge temperature' which may or may not move in lock stay with ambient temperature.
        • Rich G.
          • August 31, 2002
          • 1405
          A standard for performance in aircraft piston engines is 59F (15C) and 29.92in of pressure. I would assume it's similar for dyno results. Cooler and higher pressure is better than hotter and lower pressure.
          • Jack P.
            • March 19, 2009
            • 1135
            Thanks for the info. So which day is the best , all things being the same?
            30,60,90 ? no adjustments to carb or timming
            Jack
            • Michael W.
              • April 1, 1997
              • 4290
              Much like the leading brand of adult comfortware- Depends.
              Was the carb jetted for the 30 degree or the 90 degree day?
              • Jack P.
                • March 19, 2009
                • 1135
                It was jetted at some factory in Holley Land. I have not taken it apart since buying it new, a couple of years ago. It is the proper Holley for the L79.
                So, we don't know what we have ,
                Jack
