HD C2 rear end cover ? - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Is a hd rear end cover really needed, i have had 4 cars with the original without any problems....
    JR
  • Gary R.
    • March 31, 1989
    • 1796
    Re: HD C2 rear end cover ?
    The HD covers are very good, they have thicker ears that should not break if incorrectly loaded,the iron is said to be better as well. Do you need one? as long as you correctly load the originals and street drive probably not. I use them in the 12 bolt conversions.
    • Michael F.
      • June 4, 2009
      • 291
      Not if you torque your spring bolts correctly. Or you are going to do serious stuff at the track.
      • Lynn H.
        • November 30, 1996
        • 514
        While I am sure the improper installation of the spring, and hard use of the car can result in breaking of the cover, most of the broken covers I have encountered were the result of someone improperly jacking the car up from underneath.
        Lynn
