'65 gas tank hose clips - NCRS Discussion Boards
  • Twan B.
    • June 30, 2005
    • 207
    Can anyone tell me if it's safe to use the original clamps for the fuel hose that fits just outside the tank. I do have good experiance using these on my cooling system but I'am a littlebit fearful to use these on my fuelline.
    Does anyone know if I can use them safe?????
    Twan
  • Wayne M.
    • February 29, 1980
    • 6414
    Re: '65 gas tank hose clips
    Twan
    Twan -- depends on whether your fuel hose is the original and is reduced slightly in diameter where the original clamps have resided over 40+ years. I think you could use the original clamps with NEW hose, without problems. JMO, though. Here's a previous post on the clamps themselves, with several pictures.
      • November 30, 1997
      Twan -
      Since you're replacing the tank, replace the piece of 3/8" fuel hose too from the tank to the line on the frame, and the green spring clamps will work fine; those connections are sealing vacuum, not pressure.
      • Wayne M.
        • February 29, 1980
        • 6414
        Twan -
        John -- if I remember my hydraulics, yes, those lines near the rear frame may be under vacuum (depending) where -- like on the kick-up and further to the rear, the fuel level in the tank, and the rate of flow/consumption. Of course, on the discharge side of the fuel pump, weak clamps or non-flexible /aged hose could be the problem spots.
        After hot engine shutdown, heat soak in the engine compartment will tend to push a bit of fuel backwards towards the tank (if the pump diaphragm will allow bleedback).
        But with a cold car (ie. parked overnight), Twan is more likely to see weeping/dripping from the rear fuel line clamps than during operation; again, worse with a full tank.
