73 Ignition Lock Cylinder Removal - NCRS Discussion Boards
  • Jim S.
    • August 31, 2001
    • 730
    Re: 73 Ignition Lock Cylinder Removal
    First of all, you do not absolutely need the compressor tool. However, it is a LOT easier with it.
    Bill,
    Actually it is just the opposite. You need to lock the upper shaft from telescoping in order to use the compressor tool. You can install and tighten the star screw to lock the shaft. However, the star screw does interfere with some tools. So you can use a #20 allen set screw 5/16-18 UNC thread. And thread it down inside the upper shaft to lock it.
    Jim
    • Wayne W.
      • April 30, 1982
      • 3605
      Bill, I did by 72 t&t column without the tool, It may take another hand to slide the clip back on when you push the lock plate back down, I used two flat blade screw drivers on push the plate down.
      Jim
      But, you will be lucky if you don't break something or stab yourself with those screwdrivers. Look at the tool. Its easy to make one.
