rear crossmember bushings 63-67 - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Is it ok to reuse your old bushings once you remove them for blasting and painting the crossmember. how long do they last, they look good i think new ones are about 140 a pair........
  • Peter J.
    • September 30, 1994
    • 586
    Re: rear crossmember bushings 63-67
    Jim,
    I had mine out when I sent the rear end to Bairs and sand blasted and painted the crossmember and put it back in with the original bushings more than ten years ago with out any trouble. Did you have fun getting them out?
