c2 steering column help - NCRS Discussion Boards
  • John S.
    • May 4, 2008
    • 424
    Need some help here. I just had my speedometer rebuilt (had 2 bad gears in the odometer train). I put everything back together and everything works awesome. One small problem, I have these 2 washers left. (1st pic) I know they go up at the top of the steering column, but where? I am thinking the flat one goes on the top of the spring and the wave one goes up against the underside of the steering wheel. Anyone have the blow up diagram?
    I also attached 2 other pics. One is of the date on the back of the cluster. what does the 015 stand for? Threw in the last one when I was finished and had all the gauges and glass cleaned up. Thanks for the help.
    John Seeley
    67 Black/Teal
    300 hp 3 speed coupe
    65 Maroon/Black
    35k mile Fuelie coupe
    • November 30, 1997
    Re: c2 steering column help
    John -
    I suspect that the "015" refers to the line or department at AC that assembled the cluster; photo below of the date stamp on my original '67 cluster also has the "015" after the date.
    • John S.
      • May 4, 2008
      • 424
      Thanks John. Any idea on the 2 washers?
      John Seeley
      67 Black/Teal
      65 Maroon/Black
