Replacing seat Belt ancor how to put in rivets? - NCRS Discussion Boards
  • Robert K.
    • November 17, 2009
    • 64
    Has anyone ever tried to replace the galvanized seat belt suppport brackets 4 in all; which mount under the body outside that you bolt your seat belts into? I have a set of the old original rivets but how to hold them in place so you can beat the other end? Any clue on this there is no information in any book I have to describe this?
    Thanks.......
  • Keith B.
    • March 7, 2008
    • 928
    Re: Replacing seat Belt ancor how to put in rivets?
    years ago when I was little helping dad restore his 67 and we replaced a lots the body rivets I would hold the flat spot of the rivet down with a big sludge hammer while he was under the car with a punch and another hammer penning them over. with a little practice you can make them look just right
    • Robert K.
      • November 17, 2009
      • 64
      Thanks my son will be here for the holidays, so you know what he will be doing. you think an air hammer would work?
      • Philip C.
        • December 1, 1984
        • 1117
        Thanks.......
        Hey Bob, Hope the body is off the frame Phil 8063
        • Paul D.
          • September 30, 1996
          • 491
          Robert, The air hammer worked great when I replaced a seat mounting plate on my 71. Rivet was barely accessable from underneath and the rivet setting attachment on the air hammer made it possible. Body was on the frame on my car. Use biggest hammer you can fit against the rivet head for support. Important that hammer fits flat against rivet head. On mine, the head of the rivet sat recessed within another fiberglass panel. Chip.
            Bob -
            An air hammer with a rivet set tool works great for me; I use a regulator at the gun set at about 20 psi.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11356
              Bob -
              I recently helped a friend do about 80 rivets on his 65 fuelie, but while the body was up in the air on a lift. I was "backup man" using a heavy piece of bar stock while he was underneath using the air hammer with the special riveter head like John's. They came out great!
              Rich
              p.s. I couldn't imagine being backup man 8 hours a day at the factory though. My back was sore that night.
              • Robert K.
                • November 17, 2009
                • 64
                Bob -
                Thanks John,
                I thought so but where do you find the a rivet set head?
                • Robert K.
                  • November 17, 2009
                  • 64
                  Anyone know where you can find a air hammer rivet head? Thought I'd have to make one since I can't find it?
                  • Paul D.
                    • 491
                    Look at the above website (if I got it pasted properly). That's where I got mine. Lots of neat airplane tools if you need such. Chip.
                    • Robert K.
                      • June 30, 2001
                      • 212
                      John,
                      What is the purpose of the off-set in the rivet set? How does this differ from a straight shank and why?
                      • Steve L.
                        • June 30, 2001
                        • 763
                        You can make a rivet head for an air hammer by cutting the tip off a pointy chisel far enough to create about a 1/2 flat spot. Then put the chisel in a lathe or a drill press.
                        Get a dremel stone that is 3/8" dia and about 0.2" wide. Run the drill press/lathe and place the dremel stone axis at 90* to the drill axis. Grind a concave that is about 0.050" deep.
                        The tip is then identical to the sets that the vendors sell and only takes about 5-10 minutes.
                        To set my #4 body mount nut cage, I cut the chisel to it's mininum length and created the above head. It was the only way I could get into that tight spot.
                        Steve L
                        73 coupe since new
                        Capital Corvette Club
                        Ottawa, Canada
                          Originally posted by Robert Kerestes (36438)
                          John,
                          I have an assortment (short, long, straight, bent) - just depends on access; got them from Aircraft Tool.
                          • Harry S.
                            • July 31, 2002
                            • 5338
                            Bob, I replaced my 63 brackets as they were rusted and stripped. At the end of the day I used pop-rivets as that was the easiest way.
                            When the body comes off this year I will replace with OEM rivets.
                            • Robert K.
                              • November 17, 2009
                              • 64
                              Harry,
                              Since we had this conversation earlier in the year about the seat belt anchor rivits, I have given up or not attempted to install the outer seat belt anchors. They won't fit, or shall I say between the frame and the fiberglass body where the brackets mount to. Any suggestions?
