'69 wiper-door vac. can fastner - NCRS Discussion Boards
  • Graeme B.
    • October 23, 2007
    • 213
    Hi all, can someone tell me if the screws are the same as the wiper-door mounting screws.Also do the bushings go on the inside or outside of the bracket? (early style can) Thanks,Graeme.
    • 43279
    Re: '69 wiper-door vac. can fastner
    Graeme------
    The wiper door actuator mounting bolts are NOT the same as the wiper door-to-"hinge" bolts.
    The flange on the bushing is on the outside of the bracket.
    • Graeme B.
      • October 23, 2007
      • 213
      Thanks Joe,that makes sense. Do you know if the screws are available? Cheers,Graeme.
        • 43279
        Graeme-----
        They're not available any longer from GM. They may be available in reproduction, though. I'm not sure about that.
        • Chuck S.
          • April 1, 1992
          • 4668
          Oops...My deleted post was the right answer, but for a different question.
