Wiring Harnes Clips and Routing for 1955 V8 - NCRS Discussion Boards
  • Michael B.
    • January 31, 1980
    • 61
    Because there is no Assembly Manual for the 1953-55 Corvette, I am told that one can use the 1956/7 Assembly Manual as a guide to install the 1955 V8 Corvette wiring harnesses and clips. Is this true or is there another document to use to route the 1955 wiring harnesses?
    • May 31, 1974
    • 8368
    Re: Wiring Harnes Clips and Routing for 1955 V8
    that portion of the wiring harness that goes to the starter solenoid goes behind, alongside of and to the front of the battery, unlike the 56-7 AIM. mike
    • Jack H.
      • March 31, 1990
      • 9906
      There IS an AIM for '53-55 Corvette but it's not worth the paper it's written on... It's essentially a compendium of 'loose' quality hand drawings dealing exclusively with body/panel components.
      • Roy B.
        • January 31, 1975
        • 7044
        Other then what Mike said you can basicly use the 56 AIM PG wireing
        • Michael B.
          • January 31, 1980
          • 61
          Mike, Roy, Jack,
          Thank you.
          Mike Bailey
