Bench Testing Wiper Motor on a 1967 Corvette - NCRS Discussion Boards
  • Farrell H.
    • January 1, 1984
    • 1
    Can anyone tell me how to test the wiper motor off my vehicle. Which one of the three terminals is used as ground and which one is positive? First time on and thank you in advance for your help.
    Farrell
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: Bench Testing Wiper Motor on a 1967 Corvette
    Farrell, This is a post from earlier this year. I don't have my shop manual in front of me but I believe this procedure is correct.
    https://www.forums.ncrs.org/showthre...+test&uid=9013
      Plus, your copy of the '67 Chassis Service Manual should give you step-by-step instructions for: (1) testing on car, and (2) bench testing...
      • Ray G.
        • May 31, 1986
        • 1189
        Farrell
        Hello;
        http://willcoxcorvette.com/repairand...lp.php?hID=256
        Ray
        I hope you dance
          Here's how it works - it's hot all the time (with the key in "on" or "accessory"), and it's controlled by switching grounds through the switch body to the cluster. If either the motor or the switch aren't grounded properly, the motor won't work.
