Re: Fuel getting into modulator vacuum line
After restoring my 54 back 3 years ago, I had fuel in the modulator vaccuum line as well. After checking the vaccumm at the manifold, I found the vacuum was very low, I think about 10" Hg. I checked timing, and the VALVE LASH, and found that the engine rebuilder had adjusted the intakes way too tight, causing intake valve leaks in 4 cylinders. After I readjusting them all HOT, the fuel in the mod line went away.
Joe
Joe
