Battery charger - NCRS Discussion Boards
Battery charger
  • Don W.
    • September 30, 1997
    • 492
    Battery charger
    I have an older 6 amp 2 amp craftsman battery charger. I put it on my optimus battery and the needle stayed at 4 amps for 2 days and the battery heated up. I let it cool and started the car. When I set it at 2 amps the gauge goes to zero. I think the charger is shot.
    Any input?
    Any recommendations on new charger?
    Don
  • Rich G.
    • August 31, 2002
    • 1405
    Re: Battery charger
    Could be, but it also could be the battery. I had a sealed battery in an airplane that went dead because I'm an idiot and left the master switch on for a week. I tried to charge it and it stayed at 8 amps (10 amp charger) for a long time and it got warm. I decided to see if it would start the plane and it did, so I went flying. About 2 minutes later the 50 amp alternator breaker popped.
    Remember, the charger (or the charging system) is trying to get the voltage up to a level that can't be had if there is a bad cell. So the charger or the alternator just keeps on pumping until something gives.
    I would put the battery on a tester before you hurt your charging system, just in case.
    Rich
    • Gary B.
      • September 30, 1987
      • 305
      Re: Battery charger
      I think it is time to get a "Battery Tender" device. I just bought 2 Shumacher ones from WalMart. $19 US each. Work great.
      • Bill I.
        • January 29, 2008
        • 554
        Re: Battery charger
        Optimus batteries should never be charged at 6A. They like 2 or less. No wonder it got warm. Bill
        • Steven B.
          • June 30, 1982
          • 4011
          Re: Battery charger
          Agree! A number of years ago I did the same and very soon the case "expanded". It got very hot and that was the end of the battery.
          Steve
            • 15632
            Re: Battery charger
            Any input?
            Don
            Don,
            I am told AGM (Absorbent Glass Mat) batteries require a special charger. I do not know if Optima is that type of battery, but it may be. I have been told if the proper charger is not used either the charger, the battery or both can be damaged. I have no personal experience with this type of battery, and am only repeating what I have been told, and have not verified this information myself -- I have no need to. You might want to do some research on this matter though.
            • Rich G.
              • August 31, 2002
              • 1405
              Re: Battery charger
              I am curious. If the battery isn't happy with a 6 amp charge rate (and I have heard this, too), what happens in the car? There are times when the charging rate can be 30 amps.
              Is it just a matter of how long the charge is applied?
              Rich
                • 15632
                Re: Battery charger
                I don't think the difference is the rate of charge. I believe the voltage is pulsed during charging, or they put an AC frequency on top of the DC. I don't know or understand the whole story, but I have been told this (wrong type of charger) is the reason for the high failure rate on the latest reproduction batteries that are not lead acid style.
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17940
                  Re: Battery charger
                  FYI - link to Optima battery charging info. Gary....
                  NCRS Texas Chapter
                  https://www.ncrstexas.org/
                    • 15632
                    Re: Battery charger
                    See part #9 in this link:
                    Learn how a lead acid battery works, more about battery maintenance and the difference between flooded, AGM and gel batteries. Read the tutorial today.
                    • Gary S.
                      Super Moderator
                      • February 1, 1984
                      • 460
                      Re: Battery charger
                      How about the solar trickle charger linked to the link above. Anyone see anything wrong with using one? Gary
                      Get the Best Solar Powered Battery Chargers and maintainer. Whether you a solar panel for an RV or marine application or a gate opener, we have the stuff!
                      Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
