Jerry and I have been attempting to ID my 4 speed transmission that is in my '62 Vette.
Something doesn't seem quite right with the numbers if it is the original transmission, which I thought it was.
Jerry came up with this:
David Bates
Feb 6th, 04, 1:41 PM
Dave, What you have is a 1st design Super T-10 which was only available as an over-the-counter complete transmission designed as a direct replacement for the early Corvette T-10. They were made from 1968 through early 1972 and did have 10-spline input and 27-spline outputs like the early T-10 and early Muncies. There were several gearsets available for them including 2.23:1, 2.43:1, 2.64:1 and 3.44:1 first gear ratios. Some even had 9310 nickel inputs (with 0.060" wider gear) and clusters installed (Also had a 0.060" wider front gear to mate with the wider input) which had much higher torque capacity. Later 2nd design ST-10's all had 26-spline input and 32-spline outputs like the 71-74 Muncies.
All in all, a good transmission. The only weak point is they have a tendency to seize first gear to the mainshaft. There is no sleeve on the mainshaft for 1st gear like Muncies and ST-10's.
Anyone care to add their 2cents?
David Bates
