63 Dip stick tube - NCRS Discussion Boards
63 Dip stick tube
  • Michael G.
    • November 12, 2008
    • 2158
    63 Dip stick tube
    The upper dip stick tube on my 327 rotates freely, even though its all the way down in the hole. Anybody know the best way to stop this rotation? I tried a new Paragon repro, with the same result.
    Mike
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 63 Dip stick tube
    Mike
    Michael,
    Yep, take it out, clean it and clean the hole in the block. Then JB Weld that sucker in the hole. Works and eliminates that annoying little leak that runs down the pan.
    JR
    • Michael G.
      • November 12, 2008
      • 2158
      That's easy enough, thanks Joe
      Mike
      Mike
      • Bill W.
        • November 1, 1977
        • 402
        Michael,
        If you use a pair of vise grips and carefully "egg shape" the loose end of the tube it will tighten up the fit. Go slow or you will buy a new tube! The small amount you bend the tube should not cause an oil leak. Bill
        • John D.
          • December 1, 1979
          • 5507
          Doesn't Chevy still sell that tube? I remember that on my 63 we goofed and used the original tube over. Was a mistake in that the tube was far from tight. Installed a new one I bought from local Chevy dealer. Problem solved.
