Nut & bolt finishes for '70 - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    #31
    Re: Nut & bolt finishes for '70
    Originally posted by Steve Geldart (49781)
    Based on replies, I am getting concerned about the chemical dip process. Before spend the money on a beadblasting cabinet... has anyone had luck using a tumbler to remove rust on the hardware, and then doing the plating? Scott at Palmetto says that is not a good alternative. But thought I'd check with you all.
    I've used one of the tumblers from HF with the ceramic pyramids. I've used it once. I let it run for 4 hrs with the front a-arm busing bolts and washers. It helped but it is very slow. A wire brush is faster. So I don't use it anymore.
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • Chuck S.
      • April 1, 1992
      • 4668
      #32
      Originally posted by Alan Drake (43261)
      ...Once parts are cleaned if they rust up a little before plating I would use one of the high ph products to clean up rust and then rinse with distilled water
      There are many ways to skin a cat, but Steve should be aware...Once carbon steel is clean to "white" or "near white" condition, it will begin to form a rust film almost instantaneously after being wetted with water. It will make the rusting after blasting seem like a glacial process.
      If distilled water is used, the plan should be to rinse them and throw them directly in the crock pot after rinsing. But, then the problem becomes a timing problem, because the fasteners will have been in the parkerizing solution differing amounts of time.
      • Gerard F.
        • June 30, 2004
        • 3806
        #33
        Steve,
        Take a look at this thread:
        https://www.forums.ncrs.org/showthre...69291&uid=5750
        There's a Restorer article on Gray/Black phosphate in it. Here's a copy of the article:
        https://www.forums.ncrs.org/attachme...4&d=1240465614
        Jerry Fuccillo
