94 LT-1 spark plug wire clips - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    Joe or anyone else do you have any GM part numbers for the clips that attach to the metal brackets off the cylinder head. towards the front of the engine
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 94 LT-1 spark plug wire clips
    Hi Keith !
    There are several different clips on a 94. I assume you mean the ones that are verticle. As you look at the driver's side front, I believe the first clip is 12132272 and it holds four wires.
    As you move toward the center of the engine behind the ASR box, you'll see what I believe is part # 12073948 It holds four wires.
    Then the rear one holding two wires is # 12043158
    If your dealer has a parts schematic, they are shown as items 233 234 and 235.
    None show as available.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
      • 43271
      Keith------
      If these are "4 wire" type pieces, I believe they are either GM #12059510 or 12059514. However, it's a moot point because both are discontinued. It's possible there is a new part number I don't have. If so, your dealer will be able to cross reference from these numbers.
      • Keith B.
        • March 7, 2008
        • 928
        I called the dealer and they had two types listed one that holds 4 wires and the other that holds 5 wires. so I ordered two that holds the 4 wires.
          • 43271
          Keith-----
          Did they cross-reference from the numbers I mentioned? If so, please let me know the part number you get.
          • Keith B.
            • March 7, 2008
            • 928
            Keith-----
            when I get them I will post the mumbers
