1961 Clutch Pedal - NCRS Discussion Boards
1961 Clutch Pedal
  • Gerald C.
    • June 30, 1987
    • 1299
    1961 Clutch Pedal
    I just got my 1961 back from getting it serviced and it was the first time I drove the car. (It had been sitting for 26 years).
    My question is...they clutch engages at the top of the pedal travel and is this normal?
    I have a 1963 and it catches at the lower end of the pedal travel.
    Jerry
    Re: 1961 Clutch Pedal
    Jerry
    Jerry -
    There's only one way to correctly adjust the clutch. You make the adjustment so you have 1" to 1-1/4" of pedal free travel (from the fully-up position, against the rubber bumper, to the point where you feel resistance when depressing the pedal); the dimension is measured at the pedal pad surface. Inadequate pedal free travel can result in frying the throwout bearing.
