Anyone know this 55 Corvette. - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    Just a shot in the dark but any one know who might have bought this 1955 Corvette.
  • John S.
    • July 29, 2009
    • 640
    Re: Anyone know this 55 Corvette.
    don't know who bought car, but after looking at engine compartment i have a question. being serial #1392 this car is near the transition time where the vacuum advance become nonoperating and the 2351 carb is in use. this car displays a functional va and uses the 2351 carb. is this a rare combination or should this car, with a functioning vacuum advance, have a 2218 carb.
    • Roy B.
      • February 1, 1975
      • 7044
      By the JM no! But !!! Is possible ??
      by the way what is your 55 #
      • John S.
        • July 29, 2009
        • 640
        ve55s001576 0362409
        • Roy B.
          • February 1, 1975
          • 7044
          ve55s001576 0362409
          Everything on your 55 will be second design with no disputing
          by the way is your wiper switch have two vacuum lines and the #5 lower shroud piece that supports the bottom area having thoses two holes
          • John S.
            • July 29, 2009
            • 640
            far enough back to have second design windshield washer system!
            • John S.
              • July 29, 2009
              • 640
              wiper switch is the one you posted. t shaped, with a cable on one end and dead ended on the other end.
              • Mike M.
                • May 31, 1974
                • 8409
                http://www.truspeedmotorcars.com/vas..._stock_no=1760
                is that grey vette your old one roy?mike
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Yes 55 that used the foot plunger type used that switch only// NO other design like it and you'll never see the correct one for sale , always the vacuum type and people restoring a 55 use the wrong one. It will be in the new JM
                  • John S.
                    • July 29, 2009
                    • 640
                    does the first design (pedal on the floorboard) use both type of switches?
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Not sure , but most all that use the plunger foot design the switch has no vacuum lines , A survey needs to be done on 55's but then there are so few left I don't see that happening in my life time so guessing on when and how things happened is all we can do now on many parts.
                      • David V.
                        • April 30, 1991
                        • 88
                        Neat Thread. How many 55s are left in your opinion Roy?
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          Just guessing 200 of 700 by the number of shielding I've sold over 20 years about 100 units.
                          • David V.
                            • April 30, 1991
                            • 88
                            WOW! That's rarefied air your breathing there Roy. Congratulations on being one of the rare owners of a 55.
