55 owners - NCRS Discussion Boards
55 owners
  • Roy B.
    • February 1, 1975
    • 7044
    55 owners
    Can you check and see if your wiper switch design looks like this one with out vacuum lines , the pic. is not good but the best I have . Goes along with this pump design
    thanks
  • Mike M.
    • May 31, 1974
    • 8409
    Re: 55 owners
    can ya take a better picture of the switch. 55 1416 has the style pump you have pictured .mike
    • Roy B.
      • February 1, 1975
      • 7044
      Re: 55 owners
      Mike! not at this time ,but does your's have vacuum lines on the switch behind the dash for hoses Thanks
      • Robert J.
        • September 30, 2004
        • 117
        Re: 55 owners
        Roy mine has the hose tubes. To the best of my knowledge its the original. 1006 used the foot pump no hoses to the switch.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: 55 owners
          Well being #06 it could be carried over from a 54 but all 55's should have none
          • Robert J.
            • 117
            Re: 55 owners
            It was in a box with the rest of the dash parts with the little washer stop missing. So it could be from a 54. Next time I hear from Ray I'll ask him what 08 has....bj
            • John S.
              • July 29, 2009
              • 640
              Re: 55 owners
              roy, are the bezels different on these switches? can a 55 bezel fit on a 53-54 style switch? if bezels are different this might be a good way of telling which switch is in use without removing knob or crawling underneath dash.
              • John S.
                • July 29, 2009
                • 640
                Re: 55 owners
                having found a better set of pictures i see the bezels are the same! plenty of the switch with vacuum lines are available. of coarse, no leads on 55 style.
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Re: 55 owners
                  Looking at so many wiper switches on e-bay they ALL say for 53 to 55 , they may not know 55 is different and if they saw a 55 would think it was for some other car. I remember that early 53 use a foot pump also, so the switch should be the same.
                  • John S.
                    • July 29, 2009
                    • 640
                    Re: 55 owners
                    that early 53 foot pedal is the one that resembles the later 55 foot pedal. i purchased one thinking it was a 55 pedal. should have noticed that the assembly on the 53 is much longer(appr. one inch). it is very impessive that you would put these two switches(early 53 and 55) together as possibly being the same part! in the new judging guide is this switch mentioned for the first 180 cars?
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Re: 55 owners
                      Noland's book say 53 used the foot pump up to 176 or so!! I cover the 55 only ( that's my thing) , others cover the 53 to 54 .Your 55 have the lower shroud piece that's screwed to the four piece radiator shroud where the two holes are? That few know about (shrouding is a FIVE piece unit)
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        Re: 55 owners
                        this is it Early 53, 55 ,56 and 57
