Washers - NCRS Discussion Boards
Washers
  • Mike R.
    • August 30, 2009
    • 321
    Washers
    I recently purchased bumper bolt kits which came with washers and nuts. The washers appear to be the same as the ones in the bins ($2.99/lb) at the hardwars store. Are these the correct washers? There are nicer thicker washers called "SAE washers" at the hardwars store which "look" more like what I would expect to see.
  • Gene M.
    • March 31, 1985
    • 4232
    Re: Washers
    Mike,
    The AIM will illustrate the correct application of washer usage or not. But we can not make a call of what you have on the washer size with out physical measurements.
    • Gary B.
      • January 31, 1997
      • 6986
