C4 Wire Loom - NCRS Discussion Boards
C4 Wire Loom
  • Floyd B.
    • November 1, 2002
    • 1053
    C4 Wire Loom
    Would anyone know where I could get this wire loom? I went to a Chevy dealer and they had no idea how to look them up. I tried a few auto parts stores and found nothing close. The chassis and engine bay have dozens of these things. This particular example secures flexible conduit protecting the sensor wires (including the knock sensor) from the heat of exhaust components.
    "Drive it like you stole it"
    • 6960
    Re: C4 Wire Loom
    Floyd, I Have A Auto Shop,i May Have Something Thats Is Close To The Pic. You Posted. Ill Look Tommrow, Send Me P.m. With Your Address And Ill Send It To You.
      • 15641
      Re: C4 Wire Loom
      Floyd those things (I would bet they are called retainers -- but then it seems every other GM part is called a retainer) come in a variety of sizes. I had to order a couple of different sizes while looking to replace broken ones on my Caprices. If you post the diameter of the loom that passes through them, your chances of getting the right part will be increased.
      • Floyd B.
        • November 1, 2002
        • 1053
        Re: C4 Wire Loom
        Thanx Terry. I think they are called "clips" - another very overloaded term in the GM parts catalog. This one looks to hold 1/2" O.D. wiring loom. There are two on each side of the oil pan. They attach to small one-hole "L" brackets that are fastened to the engine under one of the oil pan bolts. The loom holds the knock sensor and O2 sensor wires and prevents them from coming in contact with the exhaust. GM part #12015631 appears to be a 3/8" O.D. version but not exact in configuration.
          • 15641
          Re: C4 Wire Loom
          I don't think I have any that small. I had to replace several on the top of the engine, and they were in packages of ten. Isn't that always the case?
          I'll look tomorrow, if the garage isn't frozen shut.
            • 6960
            Re: C4 Wire Loom
            Terry, I Found One At My Shop , Floyd, I Sent It This Am.
              • 15641
              Re: C4 Wire Loom
              Thanks Ed. It is way too cold (single digits F) for me to rummage in the garage today.
              • Pat M.
                • April 1, 2006
                • 1588
                Re: C4 Wire Loom
                It's REAL cold here in south Louisiana today, Terry - 46F!
                • Keith B.
                  • March 7, 2008
                  • 928
                  Re: C4 Wire Loom
                  • William C.
                    • May 31, 1975
                    • 6037
                    Re: C4 Wire Loom
                    If you tell the counterman at the dealereship to look in the "Standard Parts Catalog" he should have better luvk at finding them. They were used on just about every GM car of the era.
                    Bill Clupper #618
                    • Floyd B.
                      • November 1, 2002
                      • 1053
                      Re: C4 Wire Loom
                      Thank You Gentlemen.
                        • 43290
                        Re: C4 Wire Loom
                        Bill------
                        Unfortunately, I don't think these clips are listed in the Standard Parts Catalogs. I've looked through several, including older editions, and can't find them anywhere. For the most part, the only clips listed in Standard Parts are the metal type. There are a few plastic ones, but not many.
                        The clips in question here are not found in the regular P&A catalogs, either----at least not that I can find.
                        Notwithstanding the above, I expect these clips are available from GM. It's just a question of finding the right part number. I've always wondered in the case of hard-to-find part numbers how GMSPO ever sold enough to justify keeping them in inventory? After all, if they make the availability of a part effectively secret enough, how would they ever sell one?
                        Actually, the above also applies to parts actually listed in the Standard Parts Catalog. I mean, how many parts countermen even know it exists, let alone being willing to spend the time and effort to find a part in said catalog?
                        • William C.
                          • May 31, 1975
                          • 6037
                          Re: C4 Wire Loom
                          I know that wiring parts in general are in the 8.965 group of the Std parts cat, I've got a good enough relationship with my local counterman that they will order the parts for me if I give them a P/N, or look it up in the std catalog, I'm surprised they aren't included knowing some of the things that are, but the std Parts catalog can save a lot ot wasted time looking for small electrical items that were never carries in the Divisional parts books. Suprisingly, some of the parts chains (NAPA and others) carry some odd electrical items of OEM vintage.
                          Bill Clupper #618
                            • 43290
                            Re: C4 Wire Loom
                            Bill-----
                            Yes, group 8.965 has a plethora of electrical parts of all sorts. Unfortunately, it does not have these. Many of the part numbers look like Delco-Packard part numbers as one would expect.
                            The 12015631 number that Floyd got off one of the clips looks like a Delco-Packard number to me, too. It is available in SERVICE and is a group 8.950 part. However, while it's been around since well before some of my Standard Parts Catalogs, it's not to be found in any of them!
                            • William C.
                              • May 31, 1975
                              • 6037
                              Re: C4 Wire Loom
                              Ahh, the beauty of having an old price book to look up the group number in. Yes, that is a part from my former employer without doubt.
                              Bill Clupper #618
