Backup light switch wiring - NCRS Discussion Boards
+ More Options
Posts
  • Dennis S.
    • April 1, 2004
    • 228
    Now that I have the tunnel insulation, engine and transmission installed, can somebody tell me where the backup switch pigtail goes? In other words, does it go underneath the insulation?
    • 43245
    Re: Backup light switch wiring
    Dennis------
    It does not install under the insulation.
    • Dennis S.
      • April 1, 2004
      • 228
      Thanks Joe.
      • Henry S.
        • April 30, 2005
        • 816
        Dennis,
        If you have the 67 Assembly Manual on page G399 (A2.5) you can see the back-up harness as it attaches to the speedo clip. There may be other pictures of it in the A2 section so you might check it out.
        • Dennis S.
          • April 1, 2004
          • 228
          Henry
          My car is a '69 so I looked thru the '69 AIM and can see where the pigtail is probably held by the clip on the driver side firewall, the one that holds the speedo cable as it leaves the firewall grommet. That looks like where it is going to hang. Thanks.
          Dennis
          • Henry S.
            • April 30, 2005
            • 816
            Henry
            Dennis
            Oops, sorry Dennis. I had a brain fart, didn't even notice your yellow 69 in your avatar!! Wasn't sure what the 69 AIM shows.
            • Dennis S.
              • April 1, 2004
              • 228
              Henry
              Quite all right. I found a small empty clip a little lower on the firewall, right where the tunnel starts. I knew that clip protruded thru the insulation for a reason. I am sure that is where the pigtail gets supported.
