Is this supposed to be a rubber grommet or a metal sleeve????
Early 63 PCV
Re: Early 63 PCV
Justin,
I think it's a rubber grommet and the GM metal sleeve service part came later. Look in archives as there is a detailed discussion about this from a few years ago..
Long story short, I think the sleeve bushing is the only available part.- Top
Re: Early 63 PCV
The 63 AIM does call out a change from the two separate pieces to a single grommet in May of 1963 but the change didn't actually occur in production until later. Unrestored cars as late as some in the 19,000 VIN range still have their original sleeve/grommet.
If someone happens to have a good pic of both styles, it would probably help those that have never seen the original sleeve design.- Top
Re: Early 63 PCV
The first design (steel sleeve and rubber grommet) was used until well after the change date shown in the Assembly Manual, as noted by Michael Hanson.
The '63 JG Revision Team should note that there is no reference at all in the new 5th Edition to the first design, which ran for most of the model year; only the second design (grommet only) is mentioned in the JG.- Top
- Top
- Top
Re: Early 63 PCV
Harry,
I will try to do so later this afternoon, as I have a previous appointment this morning. I will also have to clean it up so I get a good look at it. When I went out last night to investigate this, I found it to be rather greasy around this area. I will try to get a good photo to post.
And Joe,
You are probably right, as I stated it was pretty greasy back there when I investigated last evening, so maybe all that grease "preserved" it a little. It did seem to be a little hard when I stuck my thumb nail into it, but at first glance it did not appear to be cracked, or leaking around it. I am in Michigan, but my car spent the first 39 years in a much better climate (California) with the original owner, so that may have helped a little also.
I will definitely get a photo and more info later today.
It also surprises me somewhat that the latest JG does NOT mention this setup (from post by Mr. Hinckley) if it was the primary one used that late into the build. I would think the revision team for the JG would certainly want to look into this further.
Lynn- Top
Re: Early 63 PCV
The problem we have with parts such as this PCV Sleeve assembly etc is that sometimes we let the AIMS be our guide to determine if a part was used in a certain time factor and this doesn't pan out.
I am looking for a nice pic of a NOS sleeve and grommet assembly and will send it to Hanson so he can post it as I never learned how. JD- Top
Re: Early 63 PCV
In some cases, it IS close, but in many/most others, it's not. The actual/physical change on the assy line can be weeks/months after the AIM date.- Top
