keeping my 65 engine warm this winter - NCRS Discussion Boards
  • Andy F.
    • June 14, 2009
    • 26
    My first year with a 65 parked in the cold garage for the winter. Any suggestions on if I need to and how to keep the engine warm? Thanks, Andy
  • Paul H.
    • September 30, 2000
    • 683
    Re: keeping my 65 engine warm this winter
    Andy, you don't need to keep the engine warm. I have always changed the oil before winter, give it a good polishing, top off the gas tank and put it on a good battery tender. I also look for the few opportunities when the roads are clear and dry to give it a little exercise. If you can't drive it, better to let it sit than start it periodically as that will build condensation in the motor.
    • Andy F.
      • June 14, 2009
      • 26
      Thanks Paul.....I was hoping you would day I had to take it to Florida for the winter
      • Paul H.
        • 683
        That actually sounds alot better to me NCRS Regional in Orlando in January.
        • Joe C.
          • August 31, 1999
          • 4598
          Hang a life sized poster of a naked Angelina Jolie next to it.
          • Christopher R.
            • March 31, 1975
            • 1599
            The cold isn't going to hurt anything.
            What will hurt the car in an unheated garage are:
            1. rodents coming in out of the cold; and,
            2. temperature changes that produce condensation on metal surfaces (which will make rust).
            After years of struggling with these 2 things, I now put the car in a bag with dessicant.
            As stated, fill the gas tank; change the oil; cover the car; and, put an automatic charger on the battery before you put the car to bed for the Winter.
              • May 31, 1974
              • 8389
              i like yer body warmer. mike
                • May 31, 1974
                • 8389
                forgot to mention if you want to keep the car chilled, hang poster of hillary and nancy. make sure ya got antifreeze that goes to minus 30.mike
                • Jean C.
                  • June 30, 2003
                  • 688
                  What Mikie says.
                  Cheers,
                  • David C.
                    • May 17, 2007
                    • 62
                    Guaranteed not to get pregnant with that suggestion
                    • Tom K.
                      • August 31, 1989
                      • 28
                      what is a dessicant???
                        • May 31, 1974
                        • 8389
                        a material that adsorbs moisture. the 53-55 vettes had a desicant bag placed in the rear license plate area so that water wouldn't deposit on the underside of the plexiglass license cover.mike
                        • Joe C.
                          • August 31, 1999
                          • 4598
                          The drawback to using a "bag with dessicant", is that if there is a small, undetected breach in the seal, the dessicant will quickly become saturated. At this point the bag becomes a seal which traps moisture and prevents air circulation. Not a good combination.
                          • Paul J.
                            • September 9, 2008
                            • 2091
                            Dessicant is also in your AC dryer. It's in the little bags that you find in the box with electronic devices, etc.
                            • Paul J.
                              • September 9, 2008
                              • 2091
                              During the last administration President Bush got off of the helicopter at the White House carrying two baby piglets. The Marine standing guard snapped to attention, saluted, and said "Nice pigs, Sir". The President replies "These are not pigs, they are genuine Arkansas Razerback hogs. I got one for Senator Hillary Clinton and one for Speaker of the House Nancy Pelosi". The Marine again snaps to attention and says "Excellent trade, Sir".
