73 Horn Relay - NCRS Discussion Boards
73 Horn Relay
  • William M.
    • July 31, 1993
    • 390
    73 Horn Relay
    Does anyone have a picture of a correct '73 horn relay?
    I bought a supposedly NOS part # 3996283 in the box and it was judged "not typical factory production" at the N.E. Regional.
    I've also seen part # 6273328 - is that a later service replacement for 3996283?
    Bloomington Gold 2011
    Corvette Magazine 9/11
    Bloomington Gold 2013
    Corvette Magazine 3/13
    • 6948
    Re: 73 Horn Relay
    Bill. I Don't Know If The 73 Is The Same As My Late 72 Its Square,
    Natural Metal With A Plastic Mounting Tab & Black Plastic Base,
    The Gm Replacement Has A White Plastic Base And A Metal Mounting Bracket Spot Welded To It.
    • Tom H.
      • December 1, 1993
      • 3440
      Re: 73 Horn Relay
      Hi William !
      Here's the one from my 16000 mile 73. VIN # 11092. I believe it to be original. Hope this helps.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • William M.
        • July 31, 1993
        • 390
        Re: 73 Horn Relay
        Originally posted by Tom Hendricks (23758)
        Hi William !
        Mine looks the same, except it's mounted with 5/16" hex heads with "Z" markings.
          • 43246
          Re: 73 Horn Relay
          William------
          The GM #3996283 was used for the entire 1972 model year. However, I don't think it was used for the entire 1973 model year. I believe it was replaced at some point, probably fairly early, by the GM #6273328.
          The GM #6273328 replaced the GM #3996283 for SERVICE in July, 1973. Then, and very unusually, the GM #3996283 replaced the GM #6273328 in November, 1977. The GM #3996283 was finally discontinued without supercession in August, 1995.
          Notwithstanding any of the above, there is a high probability that both the 3996283 and the 6273328 changed in minor ways over the years of their manufacture. If you had purchased a 3996283 or 6273328 in SERVICE back in the mid-70's, the chances are that it would have been identical to the PRODUCTION parts. Later, things sometimes change. So, it depends on just how old the "O" is in "NOS". That's often the "fly in the ointment".
            • 43246
            Re: 73 Horn Relay
            Hi William !
            Tom----
            The relay could very well be original. However, I don't think that attaching screw is.
            • Tom H.
              • December 1, 1993
              • 3440
              Re: 73 Horn Relay
              Tom----
              You are probably right. Seems we had it off at one time when I was cleaning things up. Probably used screws I had in the drawer back then. That was a long time ago ! I'm fairly certain the relay is the original. Anybody got a picture of the original fasteners................ I better dig them out !!!
              Tom Hendricks
                Re: 73 Horn Relay
                There were at least TWO recognized suppliers of the 399628 horn relay in '72-73: Essex and Littlefuse. While the different parts function alike, their geometry and external cosmetics vary. BEWARE the NCRS judge who thinks there was only one correct/original part!
                Here are pix of both parts. The Essex part has the white plastic insulator on the bottom side while the Littlefuse part uses a black plastic system. Pin out positions are different but wiring harness connectors can only plug in one way.
                • John P.
                  • August 31, 1991
                  • 94
                  Re: 73 Horn Relay
                  The pictures Jack has posted are of the 2 relays I would expect to see.They both seem to have been used interchangably and with close to equal frequency.
