Re: Now here is an interesting item
the stock system either the road draft tube or the PCV valve was to remove the oil vapors from the crankcase but the header collector or even a vacuum pump on the engine or built into the dry sump oil pump is to create a vacuum in the crankcase to cut down on the windage inside the engine.they are so efficient that you need to use pressurize oil to oil the piston wrist pins to prevent them from seizing. it also allows the use of light tension oil ring expanders so the engine will develop more HP do to less friction caused by the rings. without the external vacuum source the light pressure oil ring expanders would allow too much oil left on the cylinder walls and you would have oil getting into the combustion chambers and causing a burned piston.
