'56-67 Oil filter Unit (components) - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    It's been so long since I've had this canister apart, I can't remember what order these parts assemble. I'm guessing at bolt/copper washer. canister (not shown)/ spring/ thin flat washer/ rubber (?) seal/ conical fitting that seats on bottom center of PF-41 filter.
    Bolt head marking is "M"; can't guarantee the provenace of this filter canister assy, but the one on my early '65 is also "M" and more likely the original.
    Please confirm assembly order.
  • Don H.
    • December 1, 1981
    • 1501
    Re: '56-67 Oil filter Unit (components)
    Wayne,
    You are correct: bolt, copper washer, canister, spring, steel washer, rubber washer, cup. Good luck, Don H.
