63 Rocker Panel brackets - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Re: 63 Rocker Panel brackets
    Originally posted by Joseph Scafidi (8321)
    OK! Now we are getting some info.
    1022 No brackets or holes & 2 screws at end of rocker panel
    2833 No brackets or holes & 2 screws at end of rocker panel
    83XX Has brackets riveted
    13,XXX Has brackets riveted
    13,3XX Has evidence of brackets riveted
    17,XXX Has brackets riveted.
    Do we have any owners with cars between 2833 and 83XX that can comment?
    Most all the brackets I have seen are installed with 3/16 in. pop rivets
    9900 has brackets riveted
    • Kenneth S.
      • July 31, 1981
      • 302
      Originally posted by Timothy Barbieri (6542)
      Tom, Do you know if that rivet part # is a pop rivet. Other rivets on that page are not.
      My parts cross reference book says that rivet 3828470 is "3/16" Alum Pop Rivet with 1/4" grip range." Also, the brackets are available at Long Island Corvette.
      Ken
      • Timothy B.
        • April 30, 1983
        • 5186
        #18
        Thanks for the information about the pop rivets.
        My coupe is 031XX built second week November 62 and I can tell you for a fact the rocker panels had two holes in each end. I can't attest as to the brackets because the fenders had been replaced.
        • Harry S.
          • July 31, 2002
          • 5296
          #19
          Yep, LIC has them at $5.00 each, they are items 14-12A and 14-12B.
          • Joseph S.
            National Judging Chairman
            • March 1, 1985
            • 868
            #20
            Hi Tim, As you can tell from what I am gathering here your car may not have come with the brackets. Do your rocker panels have evidence of screws previously being used in the firs or 2nd hole in the bottom of the rockers?
            Joe
            • Timothy B.
              • April 30, 1983
              • 5186
              #21
              Joseph,
              My memory tells the two holes were used and there was evidence. The rockers have departed life with me... They were junk but I should have saved them..
              • Tom P.
                • February 1, 1982
                • 69
                #22
                #3914 (last week of November 62) does not have the brackets.
                • Mike M.
                  • May 31, 1974
                  • 8383
                  #23
                  i had a 2nd week of dec, 1962 coupe that did not have the brackets. car long gone and i don't remember vin # but do remember 2nd week dec.mike
                  • Jack Y.
                    • June 30, 2005
                    • 76
                    #24
                    Approximate birthday 30837S105000: December 15, 1962
                    • Philip C.
                      • December 1, 1984
                      • 1117
                      #25
                      Car 5528 untouched nose NO brackets or holes. Phil 8063
                      • John D.
                        • December 1, 1979
                        • 5507
                        #26
                        [quote=Joseph Scafidi (8321);456096]Does anyone have info for approximate vin when the small rocker panel bracket was riveted to the inside of the lower front fender extension.
                        I have an early car 1022 without it and no holes ever drilled, a late car 21,000 with the brakets riveted in, and a friend with a 9,000 serial number car with the brackets who lost points at judging for having them.
                        Do we think the installation of the bracket is somehow tied into the change from 2 exterior screws at each end of the rocker panel to 1 screw at each end?
                        Joe, Sorry for giving you bad info on my 9900 car. It does NOT have the brackets. John
                        • John D.
                          • December 1, 1979
                          • 5507
                          #27
                          Correction: 99XX car does NOT have the brackets. JD
                          • Joseph S.
                            • March 1, 1985
                            • 868
                            #28
                            Thanks John.
                            So we have an 83XX car with the riveted brackets and a 99XX car without the brackets.
                            I guess we need more samples in the 8000 - 10,000 range.
                            The quest continues.
                            Joe
                            • Harry S.
                              • July 31, 2002
                              • 5296
                              #29
                              Joe, I tend to think that some folks are looking in the wrong spot, does anyone have a picture with the bracket installed, to post?
                              • Jack Y.
                                • June 30, 2005
                                • 76
                                #30
                                LI Corvette shows :
                                14-12A ROCKER FRONT BRACKET (LH) (RIVET TO FENDER TIP) picture is in Online catalog
                                My response for #83xx was based on this assumption. If incorrect I will delete.
