70 Rear Suspension - NCRS Discussion Boards
70 Rear Suspension
  • Thomas C.
    Infrequent User
    • August 31, 2004
    • 9
    70 Rear Suspension
    Hello All, I'm looking for some good pics of a NCRS restored rear suspension.I am currently restoring the rear. Everything was painted black. I have the manual with finishes. How can you duplicate some of the original finishes? Thank You, Tom
  • Robert E.
    • April 1, 2004
    • 398
    Re: 70 Rear Suspension
    • Chuck S.
      • April 1, 1992
      • 4668
      A complete answer to your posted question requires a magnificient tome with voluminous illustrations and work instructions, and it hasn't been written yet.
      Try this approach: (1) Pick a specific item for restoration, (2) Search for related material in the archives and published reference books, (3) If you still have a specific question, ask it here. Answers to even specific questions can be quite detailed.
      • Michael W.
        • April 1, 1997
        • 4290
        Originally posted by Robert Eisner (41801)
        I'm not sure this is a good example to go by. As the author herself states, there were many concessions made in the interest of practicality. The biggest deviations are with respect to the half shafts and diff housing.
        Replicating the factory appearance of a small block half shaft is almost impossible as the original part is uncoated, unpainted (ie. bare) seamless steel tubing. Any sort of blasted or coated surface would not be correct.
        • Mike G.
          • July 31, 2002
          • 709
          here is my 70 lt-1
          • Chuck S.
            • April 1, 1992
            • 4668
            Originally posted by Mike Greene (38310)
            here is my 70 lt-1
            Mike, I know you don't want to hear this now, but I'm thinking you could get dinged for those spring clamp bolts...mine were black phosphate.
              • 15616
              Tom,
              Why not look for an original, well preserved, 1970 to emulate? That way you will avoid the mistakes of others. Copying a reproduction will produce a copy of a copy -- not exactly the best situation.
              • Mike G.
                • July 31, 2002
                • 709
                good to know. mine were rusted so i could not see what they started from. here is what i had when i pulled it out of the barn. thanks for the help.
                • Thomas C.
                  Infrequent User
                  • August 31, 2004
                  • 9
                  Thank you all for your help. Mike the pictures were great . I'm sure I will be asking more questions. Thanks Tom
                  • Mike G.
                    • July 31, 2002
                    • 709
                    when i am done with a car we all get together and pre judge the car prior to taking it to get judged. after we all pick it apart i change the little things like that. hopefully someone would have caught that. now that i know i can change them out one at the time with little effort. thanks for the heads up. thats why i am on here.
                    • Mike G.
                      • July 31, 2002
                      • 709
                      tom, here is the front.
                      • Chuck S.
                        • April 1, 1992
                        • 4668
                        Whew...No wonder you didn't know they were black phosphate.
                        Even if there was black phosphate remaining, it would not have survived the cleaning those bolts had to get. Chassis parts with that much rust are easily assumed to be natural rather than finished.
                        My car didn't look that rough and it had never seen the inside of a barn.
