I attached a picture of the back of my ignition switch and a picture of the engine (ammeter wiring) harness connections.
The colors don't match the diagrams. The diagram shows pink (resistor) purple (starter relay) yellow (coil) and black (solenoid). The connections have brown, purple and green together and a separate black.
The only way to fit the triple connection would have the purple wire on the solenoid connection. Is this correct?
Also why does the switch have eight connections but I only see six in the diagrams and harnesses (excluding the light)? The harness is for late 57 (After April) and my car is a late May. What changed in April and is that the difference?
Thanks in advance.
Tom
Thanks in advance.
Tom
