C1 Defroster Vent - NCRS Discussion Boards
C1 Defroster Vent
  • Charles C.
    • May 31, 1978
    • 65
    C1 Defroster Vent
    What material (metal, fiberglass, plastic?) were the orginal '61 defroster vents (the part that bolts below the dash) made from?
    Is the material judged (I don't find it in the judging manual)? The reproductions are made of a plastic and it appears you can view the material through the opening in the dash.
    Thanks.
    Charles
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: C1 Defroster Vent
    I believe they are die cast pot metal or Aluminum which was then dip painted black.
    Definately not plastic.
    • Charles C.
      • May 31, 1978
      • 65
      I forgot to mention that my '54 Vette defrost vents are a diecast metal. Perhaps GM continued with this same material (it may be the same part) all the way to '62.
      I am wondering if this is a judged item?
      Charles
      • Wes S.
        • May 31, 1982
        • 209
        Definitely die cast white metal aand dipped in paint bucket. Not judged unless they are really noticable.
        • Dennis C.
          • June 30, 2002
          • 884
          Yes, in '61 the defroster ducts were still pot metal. If you are interested in originals rather then the plastic reproductions, check the usual suppliers. I have seen them available from most of the suppliers.
          Dennis
