c3 1977 dash pad replacement - NCRS Discussion Boards
  • Susan G.
    • May 31, 2005
    • 136
    Has anyone replace the dash pad on a 1977. I know it is a big project for a C!, but need to know if this is as complicated for a C3, ie do you have to remove the windshield, etc.
    Susan
  • Alan D.
    • August 31, 2000
    • 111
    Re: c3 1977 dash pad replacement
    The windshield does not need to be removed. The passenger side lower dash must be removed. The upper screws in the instrument/gage panel must be removed and the upper screws in the drivers lower dash panel must be removed. The drivers and passenger A pillar covers must be removed also. There is a screw on the passenger side under the dash that must be removed that attaches the dash to a support. The speaker wires must also be disconnected before removing the dash. The front of the dash (nearest to the windshield) generally has clips holding the dash in place. Pull the dash towards the rear of the car. NOTE: The clips in many cases are not attached correctly making the dash removal easier. The dash can be removed by lifting one side up and slightly bending the dash to clear the A pillars. It is very important to not flex/bend the dash board any more than necessary to remove it. Remember it is 32 years old. Good luck.
    Al Dietele
