seat back repair - NCRS Discussion Boards
seat back repair
  • Gary G.
    • March 1, 2001
    • 47
    seat back repair
    I have an original seat back for my 75 coupe that is cracked vertically. I replaced the back with a reproduction several years ago, but I kept the original in the garage. Can I repair it with fiberglass or an epoxy resin? There is only one crack in the middle, and it is invisible when the seat is not stressed with the driver's weight.
  • Gary G.
    • March 1, 2001
    • 47
    Re: seat back repair
    Anyone have any suggestions for this repair? Someone has encountered the same problem in the past?
      • 6960
      Gary, I Repaired One Of My Seat Backs , I Used Fiberglass Matt And Resin And Used A Heavey Hand Weight To Hold Alittle Pressure While Drying, Some Off The Resin Bleeds Through The Crack And Thats What I Used To Make The Repair On The Outside Of The Seat Back,a Little Light Sanding, Was All I Needed And Eched The Texture Back In With A Scrib. Looks Almost Invisable When Done.
      • Gary G.
        • March 1, 2001
        • 47
        Thanks sir, that's what I will attempt this winter.
