C1 (1960) Window regulator parts - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    Does anyone know where to get parts for restoration of my 1960 window regulators? I know I can get the large Regulator Gear from a number of places. But I am looking for the parts that do the cranking. Not sure what this unit is called, but it is the part that the window handle fits on. It is the part circled in read in the attached picture.
    I have looked extensively on-line at all the normal suspect corvette parts suppliers with no luck. Thanks.
    Don Harris
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Terry D.
    • May 31, 1987
    • 2696
    Re: C1 (1960) Window regulator parts
    Donald
    Other than swap meets or E-Bay I know of no where to get that part, wish I did, as I could use one myself. Hopefully some one will jump in with a solution
    • Donald L.
      • September 30, 1998
      • 461
      Most restoration shops that have the parts will not sell the parts but will restore the regulator as it is more profitable. I believe Paragon is one such shop.
      • Jerry C.
        • November 1, 1995
        • 741
        Try Paul Mazut at 413 243 3439.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11345
          Paul is excellent! He repaired 2 C1 windshield posts for me a few weeks ago. Turnaround just a few days. Highly recommended.
          Rich
          • Richard T.
            • February 1, 1979
            • 858
            If your looking for the splined shaft that the crank handle fits on I don't think anyone sells that part. The splined tip is the same as other 40s, 50s, and 60s GM cars. I repaired a stripped spline on my 59 years ago by cutting the tip off of the bad shaft and welding on a good used tip that I got from a bone yard. If you can find a donor it can be fixed. Rich
            • Steven B.
              • June 30, 1982
              • 4002
              Try Grossmueller's.
