ID help with a master cylinder - please - NCRS Discussion Boards
  • Roger O.
    • September 7, 2009
    • 209
    I have a master cylinder that I would like to ID if possible.
    The # as I read it is 5460346. The last number is partially rubbed off . One or both of the 6s could be 8s . I have the complete master and booster and have a suspicion they are from a 73. Thanks for any help.
    • 43247
    Re: ID help with a master cylinder - please
    Roger-----
    It's a 1-1/8" bore master cylinder used for 1967 with J-56 as well as most, if not all, 1968-82 with J-50 power brakes.
    The 1967-about 1972 versions have bleeder valves. The about 1973+ versions have no bleeder valves.
    "PG" is the most common stamped code, but a few other codes were also used, especially for later C3's.
    • Roger O.
      • September 7, 2009
      • 209
      Joe,
      Thank you very much. It does not have bleeders so my suspicion of a 73 is probably close.
