Last spring I had a fuel pump go out and had to be towed. Called AAA and waited till a rookie wrecker driver showed up. He said that when it was known that it was an old Corvette, the more experienced drivers didn't want to mess with it and it fell to him as the lowest seniority. Figuring the situation was just as dangerous to call and tell AAA to send somebody else while I waited on the side of the road, I watched in agony as the rookie tried to figure out where to hook to. I've trailered a Corvette before and know how I tied it down but the wrecker didn't have the same sort of straps, just cables and chains. Got it home with no damage luckily, but I've seen for instance where those hooks the wrecker drivers use will pull through the slots in the frame and other wrecker damage.
Do y'all carry a set of tie-down straps with you in case the wrecker isn't properly equipped? Do you know what to tell the tow truck guy about how to tie down your Corvette in case he doesn't know? What about those trucks that lift by the front wheels? Can those be used safely if you're not going far (c3 in my case)? I'd like to be better prepared in case there is a next time. Advice?
