C2 front valance - NCRS Discussion Boards
C2 front valance
  • Bob R.
    • June 30, 2002
    • 1596
    C2 front valance
    Last week someone asked about the fastners on the front valance of a C2. I checked out my 63 and found the fastners missing. On the drivers side of the front there is a hole about 1/2" in diameter in the proper location. That seems a little big for the bolt even with a washer. On the right side front someone filled the hole in. I thought I would install the bracket and bolts.
    Does anyone know the correct size of the hole?
    I was working on it for a while yesterday and it won't be easy to install that bracket.
  • Doug F.
    • November 1, 1983
    • 322
    Re: C2 front valance
    As i recall the fastener is a 1/4 - 20 { NC } pan head phillips with a lock and flat washer, flat washer is aprx 5/8 " OD so 1/2 " hole is a bit large but should cover,
    When installing the L bracket / nut plate make sure the nose adj rods are in place and get them adjusted back to where they belong.
    • Gary J.
      • April 3, 2008
      • 164
      Bob, you are always welcome to drive to my home and examine my car, just leave the parts attached where they are. LOL Happy Thanksgiving
      New England Chapter NCRS
      • Bob R.
        • June 30, 2002
        • 1596
        Thanks all for the response.
        Gary I thought you could drive over with your car.
        Happy Thanksgiving
