1961 Borg Warner T10 Transmission - NCRS Discussion Boards
  • David C.
    • May 31, 2000
    • 3
    I am restoring a 1961 with a build date about January 20, 1961. The Judging Guide says that early 1961's up through VIN 2400 had a cast iron case but in other places I have found that cast iron cases were used through January. I need your feedback on which case is probably correct for a late January 1961.
    Thanks!
    David C.
  • Jim K.
    • August 31, 2000
    • 554
    Re: 1961 Borg Warner T10 Transmission
    You should be OK with aluminum on a Jan. 20 build if the transition was @ 2400 ( you must be around #4500?).
    Jim
    #5560 2/14/61 build
    • Dave S.
      • August 31, 1992
      • 2926
      Thanks!
      David C.
      David,
      My #4587 ( January 10 build) car has an aluminum case. I would say a late January car would definately merit an aluminum case.
      • Ray C.
        • June 30, 2001
        • 1132
        Search the archives using: "Dale Pearman T-10" Dale was a very knowledgeable C-1 person.
        Ray
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
