clips from corvette central will not hold down moulding on windshil and coupe back trim Help
c2 moulding clips do not hold
Re: c2 moulding clips do not hold
Hi Dennis,
I knew I was going to have to cross this bridge at some point myself, so when I came across information about it, I took notes. Someone on another forum asked a similar question about replacing a midyear windshield in March of 2008, and John Hinckley replied with the following:
"You'll need a new weatherstrip/seal (Corvette Rubber), and you'll probably find at least some of the molding retainer clips corroded/broken; get replacements from Paragon - theirs are the only ones that work. The clips can only be replaced when the windshield is out of the car." (JohnZ, post 2, 03-08-08)
Hope this helps,
Scott- Top
