67 and 65 Side pipes - NCRS Discussion Boards
  • Jim M.
    • October 20, 2009
    • 41
    Can anyone tell me if a set of 67 BB side pipes would fit a 65 small block 327/350hp.
    I recently purchased a set of aluminum pipes and possibily want to sell them to someone I know.
    I just want to make sure they would fit. He has no pwr steering or brake
  • Bill I.
    • January 29, 2008
    • 554
    Re: 67 and 65 Side pipes
    Jim, My first thought is NO. They are 2 different engines. Bill.
    • Donald T.
      • September 30, 2002
      • 1319
      They are not interchangeable.
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Jim Matera (50980)
        Can anyone tell me if a set of 67 BB side pipes would fit a 65 small block 327/350hp....
        Jim -- I believe that all C2 sidepipes were the same on the chambered section only (ie.downstream from the weld joining the curved pipe to the exhaust manifold).
        So if the front part of your pipe is original, you could "re-core" to a new GM chambered section. Or you could get someone to fabricate one or any of the 3 designs of the forward pipe (BB, SB w/2.5" exh manif; 2.0" SB), if you're not transferring from existing damaged or worn-out originals.
