1954 driveshaft (propeller shaft) length? - NCRS Discussion Boards
  • David E.
    Infrequent User
    • April 30, 1981
    • 9
    Re: 1954 driveshaft (propeller shaft) length?
    Originally posted by David Edwards (4632)
    What is the length of an original driveshaft (propeller shaft), P/N 3707878, that was installed in a 1953-54? The 1953-1955 Corvette Parts Catalog, which NCRS sells, says on page 34, Group 5.436, that it is 36" C/L to C/L of the u-joints. Is this correct? Also, are there any markings on it to help identify it as being a correct original shaft? I have a driveshaft which is just 34" C/L to C/L. Could this one be correct if the 36" length turns out to be incorrect?
    Dave -
    The Tripoli book shows the '53-'55 6-cyl. driveshaft (3707878) as 36" C-C, and the '55-'62 V-8 driveshaft (3712377) as 34-1/2" C-C.
    • David E.
      Infrequent User
      • April 30, 1981
      • 9
      John,
      Thanks for the answer, it confirms what I have found out about the lengths. I forgot that I had the 1929-1959 Chevrolet "Parts and Accessories Catalog" and I just looked in there a few minutes ago. It shows the 1953-55 6 cyl. Corvette propeller shaft to be 37 7/16" OAL, no C/L to C/L given. Subtracting the two C/L to the ends and you come up with 36". So, everything that have seen and read so far confirms that the 36" C/L to C/L is correct. Anybody have an original that they can measure?
      Thanks, Dave
      • Chuck W.
        • May 31, 2002
        • 257
        John,
        Thanks, Dave
        I have 2 originals at the shop that I can measure on Monday if no one else chimes in...
        • David E.
          Infrequent User
          • April 30, 1981
          • 9
          Thanks Chuck,
          I think I really have it nailed down about the correct length. But, it would be nice to have one or two actually measured to confirm the measurements that I have found. I look forward for your actual measurements.
          Dave
          • Chuck W.
            • May 31, 2002
            • 257
            Thanks Chuck,
            Dave
            • David E.
              Infrequent User
              • April 30, 1981
              • 9
              • Steven N.
                • April 30, 2002
                • 214
                Join Jay's long list of unhappy customer's......................
                • Mike M.
                  • May 31, 1974
                  • 8385
                  dave: have a new driveshaft made up locally. there are numerous such shops out here in the hills of western md. good luck,mike
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Mike is correct have it made "simple" and then you know it's straight and balanced
                    • David E.
                      Infrequent User
                      • April 30, 1981
                      • 9
                      Mike McCagh, Roy Braatz
                      Are there any drawings/specs available anywhere to give to someone who makes driveshafts? What do you use for the two ends and where can you purchase them? All I really know is the 36" C/L to C/L length.
                      Thanks, Dave
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        I was just looking at e-bay and C&C sells them and the price seems OK , go that way
