Shock Mount Bolts --- - NCRS Discussion Boards
  • Bill C.
    • July 15, 2007
    • 904
    Quicky question ---
    Is there a real difference between the HD/F41 and STD suspension assemblies (shock mount bolts)?
    Reason I ask is the set I have are for F41/HD and I was going to use them on my STD suspension car. I have had this set for a couple years and figured while I was freshining up my rear suspension I put them on.
    I sort of remember hearing that the assemblies are "beefyer" but the orientation of the shock would not change between the STD and HD parts.
    Any insight is appreciated.
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Shock Mount Bolts ---
    Bill,
    yes the lower shock mount bracket is different, it is angled to allow the wider F-41 shock fit without interferance from the trailing arm. The upper bolt is the same.
    Rich
    • Bill C.
      • July 15, 2007
      • 904
      Rich,
      can the HD part be used with STD shocks?
        • 43259
        Originally posted by Bill Chamberlain (47576)
        Rich,
        Bill------
        Definitely. In fact, GM discontinued the standard suspension shafts about 30 years ago and replaced them, for SERVICE, with the F-41/FE-7 shafts. After that time, you could only purchase the HD shafts for ALL 1963+ Corvette SERVICE.
        • Rich P.
          • January 12, 2009
          • 1361
          Bill,
          Joe beat me to it.
          Rich
          • Bill C.
            • July 15, 2007
            • 904
            Thanks guys !!!!
