Instrument cluster, 63 coupe - NCRS Discussion Boards
  • Tom A.
    • June 7, 2009
    • 9
    Looks like I am going to install a new dash wiring harness in my 63 coupe. While the car is down, I am considering having the instrument cluster restored. Any advice on removing the instrument cluster will be most apprectiated. I have been told to remove the steering column. This does not seem necessary to me, is it? Thanks in advance for the help.
    Tom Allen
    Re: Instrument cluster, 63 coupe
    Tom Allen
    Tom -
    Try this for removal:
    http://www.lbfun.com/warehouse/tech_...ster%20pt1.pdf
    And this for re-installation:
    http://www.lbfun.com/warehouse/tech_...ster%20pt2.pdf
    Yes, it greatly simplifies the job if you remove the steering column - only takes ten minutes. You'll find more that needs doing once you remove it (like replacing the clutch/brake pedal shaft bushings, etc.), as outlined in the articles above.
    • Tom P.
      • February 1, 1982
      • 70
      Tom,
      John's articles are great. Just take your time. Would definitely suggest a helper to assist and read the steps.
      The 1/4 X 20 rod trick works great, except that some (early?) 63's had screws attaching the instrument cluster. Don't know when the changeover occurred.
      • Joel T.
        • April 30, 2005
        • 765
        Tom Allen
        Hi Tom;
        You should remove the steering column... Otherwise the clearances are just too tight and you risk scratching the dash and surrounding areas. Removing the column is a 10 minute exercise.. it also gives you an opportunity to check out the horn mechanism, turn signals, etc..
        On the gauges, there are a number of places where you can get genuine GM reproduction gauges, the four small ones, I would just replace them versus restoring your originals... I went the restoration route and they all failed within a year and I would up pulling the dash out more times than I would have liked...
        Good luck,
        Joel
