66 BB half shaft bolt torque - NCRS Discussion Boards
  • Ed K.
    • March 1, 1980
    • 110
    My assembly manual is missing the page that indicates bolt torques for assembling the half shaft to the differential yoke and to the spindle flange. HELP!!! Anyone have the torque specs for inner and outer ends, or all we all missing that page??
    • 43222
    Re: 66 BB half shaft bolt torque
    Ed------
    Inner u-joint cap bolts= 40-50 lb/ft ( I use 45 lb/ft)
    Outer u-joint flange bolts= 60-90 lb/ft ( I use 75 lb/ft)
    • Ed K.
      • March 1, 1980
      • 110
      Thanks. I've had my 64 for 39 years, the 66 for 27. I'm beginning to wonder how I ever repaired/restored anything without NCRS membership help
      Ed
      • Gary R.
        • April 1, 1989
        • 1798
        I use the same as Joe,if you have U bolts then the torque is less I think about 15-20 but I'd have to double check.
          • 43222
          Gary-----
          Half-shaft u-bolt nuts are 14-18 lb/ft. However, I believe Ed has a big block, so he should have the caps with hex bolts. Of course, there might be some big blocks out there with u-bolts. You know what kind of big blocks those are.
          • Ed K.
            • March 1, 1980
            • 110
            Gentlemen: Yes, it's a big block with a posi rear, and it has caps on the differential yokes. A friend's assembly manual had the page I'm missing but it only illustrates a "U" bolt set-up with torques at 14-18. So, I then went to the options section hoping to find a posi rear page. Found one page but it does not show half shafts. Am I missing another page?
              • 43222
              Ed------
              I think you'll find it in the L-36 or L72 section. In those days, the cap-type axles were part of the big block option.
              • Ed K.
                • March 1, 1980
                • 110
                Nothing under L-36 or L72. Although bound, perhaps my manual was never fully complete. As for he torques, I'll proceed as suggested.
                  Ed -
                  The '66 L-72 index sheet shows the half-shaft on sheet D3 and the hood grilles on sheet D4; my '66 Assembly Manual is missing those two sheets too. However, the '65 L-78 sheets and the '67 L-36 sheets both show the half-shaft cap bolts as 40-50 ft-lbs.
                  • Ed K.
                    • March 1, 1980
                    • 110
                    Much thanks Joe, John and Gary. Hopefully I'm not about to wear you guys out but it's now onto the spring and its' Retainer Cups. Prior to reading the last issue of Corvette Restorer I had no idea that the cup sleeve was to be swaged over. I plan on it attempting it with a 1-1/4" dia ballpean hammer - placing the 1-1/4 ball on the cup and tapping on it with with another hammer. I know I should not hammer on another hammer but........... I'm reasonable proficient with a hammer and whatever else comes to mind as a potential tool. Anyone have an issue with this, or a better idea? I'd rather not rent the tool mentioned in the article. Wife is away and I have this weekend to myself to make significant progress in finishing the rear. After this it's simply assembling the spring, brakes, lines, bleed and start-er-up!!!
                    • Gary R.
                      • April 1, 1989
                      • 1798
                      That is how I do them on the springs and T/A's.
                      • Ed K.
                        • March 1, 1980
                        • 110
                        Looks fine. How did you do it? Incidentally, I just checked my 64. I did this car about 5 years ago. The T/A cups are original and look like yours. You did a nice job. On my 64 spring cups however, I never swaged them. The car has since seen about 3,000 miles and the non-swaged spring cups never came out of the spring. It's not right but perhaps not critical? Also interesting to note: I did not have any problems at all when doing the 64 rebuild. Except, apparently, that the spring cups are not swaged. Don't understand why this 66 has been difficult.
                        • Ed K.
                          • March 1, 1980
                          • 110
                          Wow - never ending issues. Spring vinyl liners? I had seperated the leaves of my curled end repro spring, painted the leaves and have new uncut vinyl liners. This repro spring had liners that were about 1/2" shorter per side than the spring leave. I would think that the liners should be longer than the leave, so that the leave slides on vinyl and does not rub on the metal leave below it. Anyone agree/disagree!
                            • 43222
                            Ed-----
                            The originals were, indeed, longer. ROUGHLY an inch, or so.
