Nothing like the smell of NOS air... - NCRS Discussion Boards
  • Patrick T.
    • September 30, 1999
    • 1286
    Especially when it's 40+ years old! I just pulled the string and opened this box and the aroma emanating from it just about knocked me over!
  • Michael M.
    • February 1, 1993
    • 604
    Re: Nothing like the smell of NOS air...
    Patrick I know exactly what your talking about. It's such a special time when you get to pull the string.
    • Tom H.
      • December 1, 1993
      • 3440
      Now, that's livin !! What are the applications for that resistor ? I'd like to save the picture.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Brian M.
        • February 1, 1997
        • 1840
        Will that part judge as an original part or a service replacement? I remember something about the squared off edge.
        • Patrick T.
          • 1286
          the '67 AIM calls out for ballast resistor #1957154 as pictured above and of course is does have the Delco-Remy stamp on it. I can't do any better than that. It sure looks better than the Chinese made repop I had on the car, it wasn't even close. They took off 3 points on originality for that one. PT
          • Patrick T.
            • 1286
            Brian, are you comparing this one to the resistor on your '67? Are they the same or does yours look different? PT
            • Michael M.
              • February 1, 1993
              • 604
              Patrick that is the correct part for your car. The judges look for the corners of the bracket to be indented like yours. It also has the correct color stripe going across the resistor.
              • Patrick T.
                • 1286
                Thanks Michael, that is good news for a change! PT
                • Wayne B.
                  • September 30, 2000
                  • 201
                  Smells like...victory!
                  • Wayne B.
                    • 201
                    How does this stuff keep popping up? You'd think it would have all been scarfed up by now, especially after all these years. Here's an ad on Craigslist for a bunch of NOS stuff for 53-57
                    Stuff this old must have got lost in someones basement
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      Reminds me of a sign I saw somewhere in Vermont 'Antiques made to order'
                      • Wayne M.
                        • March 1, 1980
                        • 6414
                        Here's what I believe is an original that I unscrewed from the firewall of a '65-67 (IIRC) junkyard Chevy product. The whole area was sprayed in black lacquer which I [mostly] cleaned off. Seems almost identical to yours. Hard to see your Delco Remy stamp, but probably 'cause there's not enough dirt to fill the imprint .
                        Seem to remember some time ago when this item was discussed, as there were 10's of millions of these produced, there was obviously multiple tooling set-ups and variations to be expected. One of mentioned back then was the size of the hole.
                          There are essentially four variations of original parts:
                          (1) With gently rounded edge and tear-away tab
                          (2) With rather straight edge and tear-away tab
                          (3) With gently rounded edge and no tear-away tab
                          (4) With rather straight edge and no tear-away tab
                          The part shown is #2.
                          I know of no judges making an originality distinction on balast resistors based on the rounded vs. straight edge shape. It's the presense/absense of the tear-away tab that receives scrutiny.
                          The thinking is production tooling changed for mounting band formation with the tear-away tab going 'bye bye' sometime in the mid/late 60's. All of the current reproduction ballasts come without tear-away tabs...
                          • Patrick T.
                            • 1286
                            Jack, can you clarify what the "tear-away tab is? Thanks, Patrick
                            • Brian M.
                              • February 1, 1997
                              • 1840
                              My car is off site at the moment, I believe I have the identical part, judged 4 times 3 with a 1 point deduct calling it a service replacemant 1 with no deduct or comment. 2 nationals 1 regional 1 chapter. BTW no deduct at 1 national.
