I believe I have the original three step, center drain, oil pan for my 300HP engine. The inside of the pan was in poor condition, probably due to old oil residue sitting inside for several years while the car was not used. I had the pan re-plated, but the inside of the pan is still not as good as it should be. The outside looks solid, but the inside plating appears thin.
Would someone have an opinion which direction I might go, like possibly knowing of a vendor who might have a new pan that looks like the original, or another plater that could do a solid re-plating inside and outside of the pan?
