Frame Question - NCRS Discussion Boards
Frame Question
  • Mark A.
    • February 1, 1996
    • 299
    Frame Question
    Will A 81 4 Speed Frame Work To Replace A Rotted 70 4 Speed Frame? I Am Not Sure If They Went To A Different Rear Suspension In 81 Or 82. If Anyone Could Help With This Question I Would Appreciate It. Mark
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Frame Question
    I believe you will find the frames are similar, but way too different for an easy swap. Bumper mounting for one thing will be a big difference. Possible, yes. Practical, no. I'd look for a more direct and correct replacement.
    Check out this site for differences. http://www.71corvette.com/frames.html
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Mark A.
      • February 1, 1996
      • 299
      Re: Frame Question
      Tom,
      Thanks for the great website. That clears up the confusion. Mark
      • Dick W.
        • 10483
        Re: Frame Question
        Mark, GM sold that frame as a replacement for all C-3's. You can make it work, but it takes quite a bit of work. For beginner's, the center crossmember will have to be replaced, the bumper mounting will have to be modified, and numerous other little items will have to be tweaked.
        Dick Whittington
        • Mark A.
          • February 1, 1996
          • 299
          Re: Frame Question
          Dick,
          After looking at the website Tom sent, it's obvious this is not an easy change. Decent C-3 frames are getting hard to find. The one I have on my 70, is rotted completely out at the rear kickups. Thanks for the reply. Mark
            • 15630
            Re: Frame Question
            Originally posted by Mark Albertus (27234)
            Dick,
            • Jordan S.
              • December 18, 2007
              • 113
              Re: Frame Question
              Consider a repro frame. I saw this company at Carlisle this year and their repros are identical to GM. They reportedly use the original GM tooling.
              • Mark A.
                • February 1, 1996
                • 299
                Re: Frame Question
                Terry,
                I totally agree that this is a no go. I'm going to restore the car to original, so the cross member removal and replacement etc, would not find approval from eagle eyed judges such as yourself. Thanks for your input and to all who replied. I learn something every time I ask a question on this site, it's the best. Mark
                  • 43272
                  Re: Frame Question
                  Mark------
                  1980-82 are designed for a completely different differential mounting. That, plus front and rear bumper mounting differences make an 80-82 a VERY poor choice for a 1970 replacement.
                  The Vette Products reproduction frames are the way to go if you need a frame. No doubt about it. Period.
