Changing my Carburetor - NCRS Discussion Boards
  • Gary J.
    • April 3, 2008
    • 153
    This may be a dumb question but I feel there must be a better way to stop the flow of gasoline to the carburetor when I change it next week. I am replacing my service replacement 3810 with a properly dated unit, other than pinching the rubber gas line with a pair of vice grips with the jaws wrapped with tape just before it trasitions to steel on the passenger side frame area, any better ideas? I would hate to ruin the rubber line, just seems like this would be a bubba method but I cannot think of another way. I don't want to be a "hack" garage mechanic.
    New England Chapter NCRS
  • Timothy B.
    • April 30, 1983
    • 5192
    Re: Changing my Carburetor
    Gary, If you are just replacing the carburetor there is no need to worry about pinching gas lines. The carburetor is above the fuel tank, just unbolt and replace the carburetor.
    The only time to worry about gasoline is when you take the fuel pump lines loose..
    • Gary J.
      • April 3, 2008
      • 153
      Thanks Tim.
      • Stuart F.
        • August 31, 1996
        • 4676
        Even in the past when I changed fuel pumps, I had made a wooden plug to put into the line as soon as I removed it from the pump fitting. You lose a little in the process, but that's better than draining the tank. Others use a bolt. It's never a fun thing to do, but then, how often do you change a pump?
        At the carb, well, you'll again have to sacrifice some gas that is in the line from the pump or filter. That is one advantage of a fuel hose there as well. My 63 had the steel line from the filter before I raised the carb with a spacer which dictated I go to a hose. The hose now points up to the fitting on the carb so loses very little gas when disconnected.
        Stu Fox
        • Dale S.
          • November 12, 2007
          • 1224
          A couple of shop rags under the fitting when you disconnect it from the carb. If you are doing the job in the garage, take the rags outside. I have a water heater in my garage. D/
